I figured that having taken out the fuse for the ciggy sockets & put the LB supply in the bottom to supply a permanent feed to the existing sockets, the now unused top fuse connection would still have a supply available switched from the ignition. So I got a 3 way ciggy socket adapter, connected an inline fuse & a thin terminal connector, slotted it in the top connection on fuse 8 ( I think), earthed the other lead from the ciggy socket adapter & there you go a separate ignition switched supply for the stuff you don't want running when the ignition is off. It's all hidden out of the way under the dash, so now I have my rubbish magnet cubby hole empty again
