Rear heater fan removal
Post by missfixit70 » Tue May 13, 2008 9:55 pm
While I was stripping out the rear trim etc today I manage to drop a ferrule straight into the one place I knew I would - the rear fan outlet #-o
Luckily it's dead easy to remove the fan, one 10mm nut underneath just under the sill, remove the side panel ( if you haven't already like I had), two screws at the front of the fan housing & one 10mm bolt on the slightly rusty looking bracket, pull it up, 4 electrical connectors & its out.
Good spray of waxoyl in the crevices while it's out & the reverse procedure to put it back :D
westonwarrior
Re: Rear heater fan removal
Post by westonwarrior » Tue May 13, 2008 10:16 pm
Carefull or you will soon be left with a shell soon, still could get it dipped to a new colour
Still that should help as that question has been asked recently.
helen&tony
Post by helen&tony » Wed May 14, 2008 11:56 am
MMmm
Not a hard job when you realise there's a nut underneath....I replaced our fan a month back, and Tony re- soldered the resistor unit to make sure.
