Rear Air Con Issue
apole
Rear Air Con Issue
Post by apole » Wed May 07, 2008 9:33 am
Hi guys,
My rear air con only blows hot no matter what it's set to. Main suspect is that the lights only come on occasionally, the panel was relocated as part of the camper conversion and the wires were extended. I will need to get at those wires and redo the connections.
I'm hoping this will be the cause.
In the meantime is there any way to see what the rear panel things it's set to do from the front, I have the digital climate control? Be nice to know if it's just a wiring issue or something more expensive !!!
Thanks.
Andy
Re: Rear Air Con Issue
Post by Doone » Wed May 07, 2008 11:10 am
I wonder if the person who did the conversion could through some light on this for you? I'd give them a call and see if they can advise. :)
Simon Jones
Post by Simon Jones » Thu May 08, 2008 11:51 pm
Hi Andy - you might find some help in http://www.igmaynard.co.uk/bongo/forum/ ... berspacher. This topic was about manual controls, but I added some info about the late type. The only thing you can do from the front panel is switch it on & off. Do the lights on the rear panel come on & change with the position of the controls? If not, then it might just be unplugged. I found that with the rear panel disconnected, the heater seemed to come on in the same state it was prior to being disconnected.
kit
Post by kit » Fri May 09, 2008 2:05 am
Simon Jones wrote:The only thing you can do from the front panel is switch it on & off.
Sorry to disagree Simon....you can take control of the rear unit by pressing and holding REAR until the Climate Control display changes and takes control of the rear unit.
Hope this is of help Andy!
Simon Jones
Post by Simon Jones » Sat May 10, 2008 11:44 am
Kit - I never knew that! There's a handy tip.
maxheadroom
Post by maxheadroom » Sat May 10, 2008 12:12 pm
brilliant how did you find that out? 8)
Keep the Faith
Post by missfixit70 » Sat May 10, 2008 12:37 pm
It's in the manual :wink: :lol: Doesn't control the temperature on mine though as that is a manual slider.
apole
Post by apole » Sat May 10, 2008 2:09 pm
Thanks guys, will help alot as to get at the wiring I have to take the fridge out.
If you hold the button for 2 secs then it tells you what the rear is set to, but you can't alter the temp.
Will have to get mine sorted as with all this hot weather it would be good to be able to cool the back of the car, gets hot in there quickly.
Andy
John the sparky
Post by John the sparky » Sat May 10, 2008 2:14 pm
Yeah agree with you Apole.... but I think it is 3 seconds :shock: :lol:
but you can turn on/off by pressing the rear button...
press aond hold, then display flashes, and you can adjust fan, and where the air comes out... head or feet....
but you cannot (annoyingly) adjust the temp, you have to adjust that on the slider in the back
