Reversing lights/camera wireing
daveblueozzie
Post by daveblueozzie » Fri Mar 07, 2008 9:51 am
Going to fit a reversing camera. does anyone know which colour's the wires are going to the reversing light, I'm being a bit lazy ,and thought id ask before spending time looking and testing.
this is the camera Ive bought , I got mine from Costco for just under £60, (same one)
http://cgi.ebay.co.uk/VR3-Wireless-Reve ... dZViewItem
Lost without my Bongo.
tridentlee
Post by tridentlee » Fri Mar 07, 2008 1:53 pm
hi dave, all i did was remove the rear light unit complete, worked out which bulb holder was for the reversing light then scotch locked the live for the camera onto that then just found an earth for the other on the camera, all wires were ran down the rear corner cover, i hope this helps , LEE
daveblueozzie
Post by daveblueozzie » Fri Mar 07, 2008 11:12 pm
thanks for your help guys ,dead easy to find the wires , temporary scotch locks ,will solder or crimp tomorrow in daylight.
Hotpot
Re: Reversing lights/camera wireing
Post by Hotpot » Wed Apr 23, 2008 12:28 am
Nice one DBO :)
I've got one very similar, so going to have a bash at this at the weekend, might have to pick your brains on this if that's ok?
Hotpot
Post by Hotpot » Wed Apr 23, 2008 11:08 pm
Has anybody got pics of doing this mod, finding the reversing wire shouldnt be too bad, but how do you tidy it away neatly and make it weatherproof? Hope you don't mind me asking, I just would appreciate some advice from somebody who's been there and done it dont want to mess it up!
daveblueozzie
Post by daveblueozzie » Thu Apr 24, 2008 7:57 am
the one i have, the camera and monitor are the wireless type, the camers wires just connect to an earth and the other wire connects to the reversing wire in the light cluster,(sorry cant remember which one it is). the monitor again two wires one to earth and one to power (i fitted mine to a spare fuse from the leisure battery). i just ran the wires between the body work and the rubber seals to make a tidy job. hope this helps.
Hotpot
Post by Hotpot » Thu Apr 24, 2008 2:43 pm
Thanks daveblueozzie that helps a lot. Got wireless infra red one from maplin (A30HN) that sounds like a similar set up, though it was a bit pricey it's got £30 off at the mo. The monitor suspect is a little different to yours, the sunvisor screens look good but this one suckers to the dash. Might just use with the 12v socket for now, but I like the idea of attaching it to the leisure battery so it's less of a temporary fitting.
Post by bigdaddycain » Fri Apr 25, 2008 10:18 am
Sounds good hotpot, dbo's monitor is quite nifty,as it is actually an extension of the interior mirror,and of the same dimension so doesn't look odd,very neat looking... :wink:
