big rubber hose
big rubber hose
any one know where the best place to order of of these is
it is the large rubber hose that you see when you lift the drivers side seat up - can go and get a photo if anyone needs it but it's the only big long one that dissapears up to the front somewhere
afraid the metal grip from the wee tube beside it was cutting into to so when drivin ysterday i noticed the guage going higher than norm so stopped and could see drips from middle so popped seat and could see the steam coming out
it's just got temp runnber tape on it and a quick top up and bleed
but would prefer just to leave bongo off road until i swap the hose and then replace all the coolant
cheers
cheers
- Peg leg Pete
hose
I thought I'd hang on for one of Flippa's silicone ones, but old one is def on it's last knockins, so service and hose replacement wednesday! I don't want to risk an overheating episode. AVA have them in stock, reasonable too, it arrived the next day, although I'd've prefered the Flippa version.
when are you likely to get them in ?
if it's within the next say 10 days - i dont mind waiting
what is the best type of clip to use - can i get these out of halfords ?
or do you flog them as well
i assume this is the one from b-bits
http://www.bongobits.com/Main.asp?PageN ... roduct=240
described as Mazda Bongo Water Hose (Above starter motor)
Hi karen , i would advise not to wait for mine as much as i want to sell them to ya ,i can't guarantee a time
sorry about that but the last lot went like hotcakes
right two full banded clips 35mm-50mm....full banded meaning no perforations in the band= the cheap and nasty type
any decent motor factors should sell em
saying that if your buying the rubber just re-use your old ones
the hose you highlight differs from your description so id hazard a guess and say that is not the one you need
take a look in the daylight tomorrow
http://www.bongobits.com/Main.asp?PageN ... Product=74
sorry useless at sending links
good luck
good luck
