Anyone got a manual, whats your clutch like oh er!
MAXANDPADDY
Post by MAXANDPADDY » Sun Mar 16, 2008 9:54 pm
Does anyone with a manual, find the clutch is poor. I've replaced the clutch plate, thrust bearing, and slave cylinder, and bled the damn thing a dozen times, but the clutch release point is still only about 1inch from fully depressed. I hired a Transit last weekend, and realised just how bad my clutch was in comparison. I'm really trying not to replace the master cylinder but thats all thats left. Is poor clutch performance a Bongo thing?
brorabongo
Post by brorabongo » Sun Mar 16, 2008 10:13 pm
I don't find my clutch any different from the works sprinter, When I say that, I mean there can't be much of a difference as I never stall either, after driver the other, if that makes any sence. :?
ボンゴの激怒 pictures
Post by bigdaddycain » Tue Mar 18, 2008 7:43 pm
Is there any kind of pedal position adjustment max? Some automatically adjust using a ratchet & pawl system,others have an adjuster above the clutch pedal itself,or sometimes there is an adjuster actually where the clutch cable joins the actuator bar on the bell housing.
Perhaps the cable has stretched?
Post by francophile1947 » Tue Mar 18, 2008 7:55 pm
bigdaddycain wrote:Is there any kind of pedal position adjustment max? Some automatically adjust using a ratchet & pawl system,others have an adjuster above the clutch pedal itself,or sometimes there is an adjuster actually where the clutch cable joins the actuator bar on the bell housing.
Would there be a cable BDC? :? I assume clutch is hydraulic as slave cylinder mentioned.
Post by bigdaddycain » Tue Mar 18, 2008 8:35 pm
So he did john...i hadn't noticed the mention of the slave cylinder :shock:
In that case, a hydraulic clutch is self adjusting, as the friction material wears, the adjustment is taken up also...So much for my original theory then :roll:
