injection pump diesel
I have a leak on the rear of the injection pump.It's coming from a circular bolt which has three flats.The bolt is situated in the centre of the rear of the pump and is surrounded by the four injection outlet pipes.I want to know if I can safely undo this bolt, seal and replace it without disturbing any internal parts.There is also a 12mm bolt screwed into this larger bolt which I have removed and replaced.Apart from this leak the engine is running perfectly but I need to stop the leak to get a mot.I just bought it and I can't use it yet
- dandywarhol
