injection pump diesel
oglivy0
Post by oglivy0 » Mon Mar 17, 2008 2:53 pm
I have a leak on the rear of the injection pump.It's coming from a circular bolt which has three flats.The bolt is situated in the centre of the rear of the pump and is surrounded by the four injection outlet pipes.I want to know if I can safely undo this bolt, seal and replace it without disturbing any internal parts.There is also a 12mm bolt screwed into this larger bolt which I have removed and replaced.Apart from this leak the engine is running perfectly but I need to stop the leak to get a mot.I just bought it and I can't use it yet :(
Veg_Ian
Post by Veg_Ian » Mon Mar 17, 2008 3:18 pm
phil 1
Post by phil 1 » Mon Mar 17, 2008 6:44 pm
I had the same problem with mine I replaced the o rings and still leaking.
In the end I had to take it to a diesel specialist for repairer they removed the pump and sent it to be rebuilt, It cost a small fortune :cry: but it's been fine since :) . As for the mot mine past two with the pump leaking
oglivy0
Post by oglivy0 » Mon Mar 17, 2008 11:20 pm
Veg_Ian wrote:Does this cover your problem?
http://www.igmaynard.co.uk/bongo/forum/ ... light=pump
My pump is leaking from the bolt/plug at the BACK of the pump.If the injector pipes are removed it is quite visible and easy to get at.It is about 20mm in size and there is a 12mm bolt screwed in to it.What i want to know is,can the 20mm bolt be removed without dislodging any internal parts.thanks
dandywarhol
Post by dandywarhol » Tue Mar 18, 2008 1:34 am
I guess you're speechless :lol:
