Afternoon Bongo Buddies.
Can anyone point me to information on removing and replacing the break fluid on my Bongo? I have looked at the factsheets and forums but cant find any info.
Cheers, Mark
Break fluid
Hi Mark
Never done it myself but I believe it's the same as any other vehicle.
Syphon most of the fluid from the reservoir and top up with fresh fluid. Starting with the wheel furthest from the reservoir, attach some clear plastic pipe over the bleed nipple, undo the bleed nipple and get somebody to pump the brake pedal until clear fluid flows, then tighten the nipple whilst they are pushing the pedal down. Repeat this with all 4 wheels ending with the one closest to the reservoir.
It's a lot easier if you get an Eezi-Bleed from the local motor factors - it's just a one man job then, although you may have to put extra washers in the Eezi-Bleeds reservoir cap to make it a good fit.
Hope the weather improvesaughton9 wrote:Cheers John, looks like my weekend job this week!
Forgot to mention to make sure that the reservoir is kept topped up or you'll suck air in to the system and have to start again
- dreamwarrioruk
Yes Ian, but I find it's quicker (and less effort with the right footVeg_Ian wrote:No need to syphon first John. Just pump it through at the first wheel.
