Undertray
BonGoRANT
Undertray
Post by BonGoRANT » Thu Mar 06, 2008 2:54 am
Before refitting the undertray I would like to replace its heavily soiled
felt(???) lining.
Has anyone done this and what materials are involved ?
Alternatives
a) refit plastic tray without new lining
b) do not refit plastic tray at all
andyfb78
Post by andyfb78 » Thu Mar 06, 2008 8:14 am
The felt lining is there to reduce noise radiated from the engine. It will make quite a noticeable difference, especially from the outside.
It may actually do this job better when saturated with oil etc!
Sorry, no advice on cleaning it though.....
Andy
Veg_Ian
Post by Veg_Ian » Thu Mar 06, 2008 8:18 am
Gunk and a power washer?
Harry
Post by Harry » Thu Mar 06, 2008 10:35 am
What felt?...mine's never had any :oops:
H 8)
http://watcherswildlife.co.uk
Post by missfixit70 » Thu Mar 06, 2008 11:38 am
Think a power washer may just destroy the felt, I tried cleaning mine with reasonable results, just using an old soft brush, some detergent & a hose. It'is amazing the difference in noise levels running with it off for a week after fitting the coolant hoses. I was getting severe paranoia with allsorts of new noises appearing everywhere :shock: Happy now, all back together & normal noises 8-[ :D
Re: Undertray
Post by bigdaddycain » Thu Mar 06, 2008 10:07 pm
I'd skip that option bongorant,that tray must offer some protection from the deluge of water that splashes up when hitting standing water hard enough? :shock:
scanner
Post by scanner » Fri Mar 07, 2008 12:27 am
It can also make a hell of a difference to cooling as it should be designed to duct the hot air away to the rear and it improves the aerodynamics of the underside no end as well.
Post by bigdaddycain » Fri Mar 07, 2008 1:37 am
Ground effects on a bongo!...i hadn't thought of that! :lol:
