broken bracket, leaking pipe, imminent mot.
Post by missfixit70 » Wed Feb 20, 2008 11:14 pm
Booked the bongo to go in for it's mot tomorrow morning [-o< 8-[ .
Did a quick level check & general inspection, glad I did, top hose by the inlet manifold has the minutest pinprick leak starting :( So I've just emailed Flippa, I knew I should have ordered the hoses last week when I had a really strong urge to get my set ordered as I put Flippa's email link up for Bernie :roll:. Have to get on to Manflex first thing for the hoseclips too, this forum is brill isn't it, you know what the problems are & how to sort them before they happen :D
Thought I'd better check the droplinks & antirollbar bushes as it sounded like one of the rears had worked loose or something, got my tyre & exhaust fitter friend to let me use the ramps after work as my back is agony at the mo - the "or something" was a broken anti roll bar bush bracket :(
He spent the next 2 hours removing the old bits - siezed nuts :roll: & fabricating a new bracket - what a star, jobs a good un, better than the originals. Will be ordering a new pair of brackets though asap - moral of the story - when you replace the bushes - do the brackets at the same time even if they look ok :roll:
I'm hoping after that frantic couple of hours that it'll fly through the mot :roll:
daveblueozzie
Post by daveblueozzie » Wed Feb 20, 2008 11:28 pm
FINGERS CROSSED FOR YOU :D
Lost without my Bongo.
bongo bri
Re: broken bracket, leaking pipe, imminent mot.
Post by bongo bri » Wed Feb 20, 2008 11:38 pm
Good luck with MOT tomorrow.
Brian
Post by mikeonb4c » Wed Feb 20, 2008 11:47 pm
Good luck Kirsty - I reckon she'll fly through. Then on to the hoses. It never ends. But I've always felt antiroll bar bushes went in synch. with rear droplinks so interesting to see a case of it actually happening! 8)
Post by missfixit70 » Wed Feb 20, 2008 11:54 pm
I did change the bushes with the droplinks - just didn't do the brackets :(
Hopefully if the brackets & hoses get here in time (Flippa reckons hoses'll be here by friday =D> ) I'll get it done on sunday, must get some antifreeze (again) already booked my friendly fitter to give me a hand :wink:
brorabongo
Post by brorabongo » Wed Feb 20, 2008 11:55 pm
[-o< All the best for tomorrow.
ボンゴの激怒 pictures
flippa
Post by flippa » Thu Feb 21, 2008 1:37 am
good luck for tomorrow kirsty :wink:
btw give that horn a honk.....a mate of mine :oops: failed his mot recently on the horn :lol: :lol: :lol: .......someone had removed it :oops: :oops: :oops:
Post by missfixit70 » Thu Feb 21, 2008 12:35 pm
IT PASSED :D \:D/ just the hose (or hoses, depending on my enthusiasm & back pain :roll: ) to do on sunday.
brorabongo
Post by brorabongo » Thu Feb 21, 2008 1:41 pm
\:D/ WELL DONE \:D/ I'm delighted for you, but dont' forget to let us know how you get on with the hoses.....Best of luck with them. :D
ボンゴの激怒 pictures
dandywarhol
Post by dandywarhol » Thu Feb 21, 2008 3:01 pm
When you replace the brackets take the rubbers off the antiroll bar, clean up the bar with fine emery cloth and rebuild with rubber grease - the bushes will last much longer. :D
flippa
Post by flippa » Thu Feb 21, 2008 7:11 pm
:D ...congrats on the pass kirsty.... :D ......the hoses are on there way :wink:
Post by missfixit70 » Thu Feb 21, 2008 7:22 pm
Cheers Flippa, Manflex reckon the clips should be here tomorrow too, wish I could say I was looking forward to it :roll:
lizard
Post by lizard » Fri Feb 22, 2008 12:30 am
Its a worring time waiting for parts to arrive.
All the best :) :) :)
F Zappa
Post by bigdaddycain » Fri Feb 22, 2008 7:34 pm
Well done with the mot kirsty =D> I know that mobility is an issue, so have another =D> for good measure... :wink:
Manflex seem to be well up to speed with bongo's now kirsty,let's hope you get sorted soon... :wink:
Post by missfixit70 » Fri Feb 22, 2008 8:33 pm
Cheers Ste, I'm actually thinking I may have to get the guys at Dunnings to do the hoses, I hate to admit defeat, but I'm not sure my back is up to it at the moment.
Don't want to screw my back up & not be able to go to the Rest of the West minimeet :roll: Either that, or I may just do the 1 hose that is about to go for now, I suppose we could have a silicone hose fitting workshop at the Minimeet :wink: :lol:
