Maintenance, maintenance
Allans
Post by Allans » Sun Feb 03, 2008 7:38 pm
Last checked our Bongo hoses December, when they were fine. Took it in this week to sort the dodgey fuel gauge (sender unit, not earth). I noticed the top hose was swollen to twice its normal size, ready to blow...8 weeks after last checked. The bleed pipe was also starting to rub through.
Sorted the hoses and blanked the EGR as I could see black smoke leaking from the pipe. Then fitted 'Dixie' air horns - just for show of course, as they're not legal on this age of vehicle. 8)
Re: Maintenance, maintenance
Post by Ian » Sun Feb 03, 2008 7:46 pm
Allans wrote: I noticed the top hose was swollen to twice its normal size, ready to blow...
What's the likely cause?
roosteruk
Post by roosteruk » Sun Feb 03, 2008 8:22 pm
wear and tear....rubber getting old....pressure in the system :lol:
Ralph
Post by Ralph » Sun Feb 03, 2008 8:22 pm
old age,
My friends wife had a Skoda Diesel, top hose did the same
they replaced it but did not check the others, one let go
in the Tyne tunnel, she did not want to stop in there and
carried on going needle off the clock, has she pulled into the
first lay by the engine stopped.
The engine would still turn but no compression at all head
scrap, it had got so hot the oil pump "it had a plastic rotor"
had melted" not worth mending the car.
So it's not just Bongo's .
flippa
Post by flippa » Mon Feb 04, 2008 6:05 pm
very sound advice ...check your hoses regularly.....people do seem to be buying this hose more then any other ....reasons why this one is prone to go ? age does seem to be the favourite....they won't last forever
Blutac
Post by Blutac » Mon Feb 04, 2008 6:08 pm
i've ordered one from ebay today, a blue one :D
flippa
Post by flippa » Mon Feb 04, 2008 6:14 pm
:lol: :lol: :lol: its on its way to you bluetac ........cheers :D :D :D
Blutac
Post by Blutac » Mon Feb 04, 2008 6:33 pm
:D :D :D Super service :D :D :D
thanks a million
flippa
Post by flippa » Mon Feb 04, 2008 6:50 pm
no problem blue :wink: btw why only the one :lol: :lol: :lol: was this the only one that was suspect :wink:
Blutac
Post by Blutac » Tue Feb 05, 2008 12:05 am
that was the only one that looked bad, i dare say after changing one more will follow :( at least i'll know which one i've changed if its a different colour :D
flippa
Post by flippa » Tue Feb 05, 2008 12:53 am
no at least you have got the suspect one out of the way...and i hope you dont need ta change anymore.. :D ......enjoy your new motor :D
Post by mikeonb4c » Tue Feb 05, 2008 1:08 am
I do wonder, if it needs changing, whether it isn't worth getting all the main culprits done as well. It would p** me off to go through all that coolant refill and bleed malarky only to be doing it again inside 2 years 'cos another hose let go. Mind you, right now I'm just living on borrowed time a la coolant alarm :roll:
Post by bigdaddycain » Tue Feb 05, 2008 10:45 am
mikeonb4c wrote: Mind you, right now I'm just living on borrowed time a la coolant alarm :roll:
You only read of the bongo's that have had coolant related problems mike,most have never had any... The coolant alarm IS a great pre-warning of a potential meltdown...
You are very dilligent with your preventative maintenence mike,odds are, you'll "catch" a problem before it occurs... (if i've just jinxed you...sorry :shock: )
Post by Doone » Tue Feb 05, 2008 3:50 pm
It was just old age. :) We fitted Mazda replacement hoses and expect them to last as long as the old ones did.
Hooligan
Post by Hooligan » Tue Feb 05, 2008 3:54 pm
I think this should be a fact sheet with pictures showing which hoses are likely to be a problem and possible replacement options....
Any takers?? :wink:
