removing interior light cover
i did a search but didnt find a mention of how to actually do it! i dont want to crack the plastic in the process.
thanks
paul
thanks
paul
which light? cab or the main one in the back?
theres a youtube vid here http://youtube.com/watch?v=G0DenImmvQg for the rear one
.......... cycling more.
- brorabongo
Lights
I tried for ages to do this.brorabongo wrote:Push to passengers side and drivers side will pull down, with a bit of help. I then used a flat blade screwdriver to release the locating lugs on the clear plastic lens.Ozric wrote:If I remember right... push it to the side and ease it out.
Sit in the passenger seat.
with both hands use as many finger tips a possible squeeze the dark plastic surrounding the light fitting around the straight sides of the right light lense.
As you squeeze slide/pull the whole unit to the left ie towards the passenger window, and pull down slightly,
Hope this helps
regards Mr & Mrs P
I found it to be the opposite on mine. Watched the video over and over again then tried it but it would not budge, there was a danger of the whole light being pulled away from the roof. My next door neighbour and my partner's son both had a go after watching the video but had no luck either.
Finally using a combination of the video method and prising the cover off with a screwdriver at the same time I was able to get it off with a few small scratches. Easier said than done for me.
