uprated headlight bulbs
MountainGoat
Post by MountainGoat » Wed Nov 14, 2007 5:15 pm
Under the bonnet. You will find fuse and relay charts in the fact sheet section within the members area.
http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
parawaiting
Post by parawaiting » Wed Nov 14, 2007 5:58 pm
MountainGoat wrote:Under the bonnet. You will find fuse and relay charts in the fact sheet section within the members area.
sorry to bea bit thick but i had already looked at that fact sheet i know what the mini blade fuses are i prusuned wrong that the others were just larger fuses are they in fact relays??
thanks
paul
scanner
Post by scanner » Wed Nov 14, 2007 7:36 pm
There is a long discussion on the subject here
http://www.dervhead.com/xmb/viewthread. ... 2#pid91013
another one with explanation of legal requirements
here
http://www.theminiforum.co.uk/forums/in ... ntry670299
Read Points 1 - 10 and then read Point 11.
http://www.autobulbsdirect.co.uk/home.php?cat=279
brorabongo
Post by brorabongo » Wed Nov 14, 2007 8:31 pm
I'm using Halfords "Super Brilliance" lamps they were 'Buy one get on free.' \:D/ They are better than what was in originally, but still not great. The lens does not seem cloudy, so I was wondering if theres something you can do to the reflector inside? I'm I right in saying reflection is just as important for a good beam :?
ボンゴの激怒 pictures
dandywarhol
Post by dandywarhol » Thu Nov 15, 2007 12:06 am
The reflector is paramount to the quality of light Brora. I've got Lidl 50% extra Tesla bulbs in and they do give a stronger, whiter light :)
brorabongo
Post by brorabongo » Thu Nov 15, 2007 1:48 am
I don't know what the reflectors are like in the headlamps, but the tail lights reflectors are just a matt silver, maybe faded :?
ボンゴの激怒 pictures
Pete & Sue
Post by Pete & Sue » Mon Jan 14, 2008 8:02 pm
I've just been to HALFORDS and bought a pair of their Super Brilliance 12v 60/55, £14.99 each on 'buy one get one free' offer. I can now see that there is a piece of road between me and the car in front instead of the usual orange fog!
I was also pleasantly surprised to find that the bulb change is quite easy, despite two batteries being in the way. Take off the connector from the bulb; press-in the catches on the two horizontal connections, take off the rubber boot, undo the clip that holds the bulb, lift out and replace bulb. Just reverse the procedure and switch on the lights.
Bugger!!!
Take off the .............!
Only kidding, works beautifully.
Pete & Sue
Turned out nice again!
Pete & Sue
Post by Pete & Sue » Mon Jan 14, 2008 8:07 pm
Forget to ask, what type of bulb is used in the sidelights and what do you recommend? I would like to get rid of the orange, candle-like glow from them.
Pete & Sue
Ralph
Post by Ralph » Mon Jan 14, 2008 8:28 pm
The lights on ours are OK on main but bad on dip, not the worst
lights I have had but just not good, you may find that by fitting
100w bulbs you could end up with voltage drop due to the wiring
not being heavy enough and you may get better light output
with more efficient rather than bigger wattage bulbs.
Best lights I ever had were on a R reg Fiesta completely standard
but you could travel on a pitch black road at the same speed as
in daylight and never a flash from oncoming cars.
Thinking about it the lights on the Bongo look very much like the
MK1 Fiesta now that did have bad lights.
Post by francophile1947 » Mon Jan 14, 2008 8:31 pm
Ralph wrote: you may find that by fitting
Also you stay legal, as 100w bulbs are for off-road use only.
brorabongo
Post by brorabongo » Mon Jan 14, 2008 8:35 pm
Pete & Sue wrote:Forget to ask, what type of bulb is used in the sidelights and what do you recommend? I would like to get rid of the orange, candle-like glow from them.
I am using "9LED w5w" lamps for the side lights. They have a blue tinge to them even though, they are sold as white :roll: I have just orderd another set form ebay:- LED
This pair I just won, I'm going to try in the Number plate lights to aid reversing. [-o<
They are also used in my front interior lights, having read of others using them.
ボンゴの激怒 pictures
Pete & Sue
Post by Pete & Sue » Mon Jan 14, 2008 9:10 pm
Thanks Brorabongo, I will try them out.
Pete.
Pete & Sue
Timnz
Post by Timnz » Thu Jan 17, 2008 2:46 am
Hella Xenon + 50% bulbs are the ones to go for, 55/60w bulbs, identical in brightness to 100w lamps but less power consumption and less heat.
cost $55 nz for a set.
Made hell of a difference in my Bongo, dipped beam lights are as good as the high beam used to be!!!
Post by bigdaddycain » Thu Jan 17, 2008 11:16 am
dandywarhol wrote: I've got Lidl 50% extra Tesla bulbs in and they do give a stronger, whiter light :)
I quite agree dandy, i had the blue versions of the tesla bulbs in my bongo, and the difference was immediate! And at £3.99 a pair, not each...per pair! I suspect they are re-badged Osrams,(they looked like it).
The Tesla bulbs were the same 55's as the original bulbs, so no worries over the legality, or the issue of overloading the circuit.
helen&tony
lighting
Post by helen&tony » Thu Jan 17, 2008 12:37 pm
I've got Osram blue bulbs...C.E. marked, and clearly stated E.U. legal...not much extra output, and the same wattage...more than adequate..if you find the output insufficient, keep some baby wet- wipes in the glovebox, and clean the lights!!!! My classic Jag used to have terrible problems in that direction....give 'em a wipe, and job done.
