i will of course only be using these offroad or or where they are legal
They also have another pointless device a little stick that lets other drivers know which way they are going. They know where they are going, why would they want to let anybody else know?parawaiting wrote:i would be interested to hear from anyone using 100/90 or 100/80 headlight bulbs, did you have to change anything electrics wise like wiring or relays?
200W = 16.6 amps so a 20amp relay is suffice.scanner wrote: 200w @ 12v = <20 amps.
<20 amps = "less than" 20 ampsroosteruk wrote:200W = 16.6 amps so a 20amp relay is suffice.scanner wrote: 200w @ 12v = <20 amps.
Retrofit HID kits are more illegal than 100w bulbs, as they require lens washing and self levelling to be legal and that is very difficult (if not impossible) to achieve.smartmonkey wrote:I think the wiring will handle it but the lenses may not. Keep any eye on them to make sure it's not too much heat for the plastic.
HID kits are getting pretty cheap and not much heat/current.
