Hi Kloonsy, it sounds like you may be a little low on atf as Kirsty suggests... In addition, in the depths of my hopeless brain,there is alarm bells ringing...Is there a speed chip fitted to your speedo? Or do you have a stick on face?
I seem to recall a little known problem with SOME speedo chips,affecting the speedo reading,which can have a knock on effect to the speed sensor for the autobox....
...just maybe....
Faulty autobox?
- Peg leg Pete
- maxheadroom
