Flush Fog Light
Flush Fog Light
Hello, Im thinking of buying one of those flush fitting fog lights and getting rid of my dangly one. Has any one fitted one of these and if so can you share how to fit the fog light in the rear bumper with me.
Thanks John (ford tinny)
- You've Been Bongod
Re: Flush Fog Light
ford tinny wrote:Hello, Im thinking of buying one of those flush fitting fog lights and getting rid of my dangly one. Has any one fitted one of these and if so can you share how to fit the fog light in the rear bumper with me.
john ask bigdaddycain as he has fitted 2 in his bumper and uses them as fog lights and reverse lights
you've been bongod
Hello Mr tinny...
First off.... mask the area you want to fit the flush foggy(ies) Check behind the bumper first for the strengthening columns.
Then i drilled a hole in each corner, when i was happy all was level and true...
And colour coded the surrounds of course....
Then, the hole can be cut using a conventional jigsaw,slow and carefully....
Please remember to cut the hole to size for the INNER part of the lamp...the shroud has to fit OVER the bumper....
No more snapped off danglies!
Flush Fog Light
Thanks BDC, My dangly is hanging buy it's last thread. I will now buy one of those flush fitting lights and fit in confidence
As long as you use a new blade, you can cut a very clean quick hole using a stanley knife - this time of year I warm the area with a hairdrier (well hot air gun
) - mark ou the line and push the blade all the way through. Then apply gentle pressure along the line.
This method works very well, but if you try to cut with the tip only then the blade can slip and cause a nasty cut (to bumper or hand
When I did mine I stitch drilled all around the opening. It provided good insurance against the cutting device wandering off line. As madmile says, the plastic yields surprisingly easily to a Stanley knife blade, so you could us that with a wiggling action and side pressure without much danger of slipping. You can also abuse your drill
by using it as a crude router with sideways pressure so that it breaks through to each stitch drilled hole - the bumper plastic yields well to that approach too. Then, as Bob says, a flat file will finish off the opening quite nicely although it is not essential as the foglamp cover plates hide all that stuff anyway. But stitch drilling is the key as it prevent you wandering badly off line.
Talking of bumpers, did anyone notice some lucky b*gger recently won a front bumper AND a back bumper on ebay for £54. Now thats what I call cheap insurance!
You've got me thinking now mike.... I may have used the drill method (then filing) to cut the holes in my bumper... It certainly rings a bell...
I assumed i'd used a jigsaw,but now i'm not so sure
Thanks to you mike for putting me onto these flush foggies too mate,i probably wouldn't have chanced doing it,if it wasn't for your excellent write up at the time....
i am still waiting to fit mine ( its to friggin cold & dark to do when i get home from work ) the weekends are taken up with pounding the streets of london on a moped trying to get to grips with the london knowledge, so i am aiming for boxing day to fit, this write up will come in very handy for me, cheers, lee.
merry xmas my fellow bongoer's & a very prosperous new year to you all.
