If your fuel injection pump leaks.........
- dandywarhol
Trying to find a possible pattern here.
Proper biodiesel (i.e. not straight veg oil) is will quickly corrode butyl rubber, but not in the typical blend ratios used (5-20% bio). This is used for seals in some fuel injection pumps, but I do not know if this includes the Bongo.
I have regularly used up to 50% blend over nearly four years with no problems, apart from the usual flush-through of accumulated crud which blocks the fuel filter when you first start using it.
Have I interpreted your question correctly, and does anyone know if such seals are a component of the Bongo fuel injection pump?
- dandywarhol
Sorry it has been long time a'coming, but I have done my bit as I said I would and have tested Dandy's old seal by total immersion. Duly baptised, I have posted my results on my server which you should be able to find here:
http://www.archewyve.net/pumpseal
In my defence, I decided to extend the test as I was not seeing any results, and so the seal has endured 32 days in the gunk.
For those who want the short version, I do not believe I could suggest that the biodiesel had affected the seal in any way at all. You can scrutinise the piccies for yourselves.
I will now leave the seal to 'dry out' for a day or two and then immerse into pure veg oil as requested by Dandy. However, whereas I half expected to see some change with bio, I certainly do not with veggie oil, but we'll see.
So, that complete, I can go off Christmas shopping now, unless I can find something else to do instead. Anything, really....
Cheers,
SH
Cheers,
SH
- dandywarhol
- Bongonaut
