TM2 engine watchdog
helen&tony
TM2 engine watchdog
Post by helen&tony » Wed Oct 24, 2007 11:06 am
I've just got my TM2 from Aus. and I know others have one fitted. What's the concensus on where best to put the sensor, and what temperatures do you set your gauge at? Looks a simple fit, but did anyone drill through the engine case to fit the sensor? Did everyone fit the oil sender option?
brorabongo
Post by brorabongo » Wed Oct 24, 2007 4:34 pm
check the last page here:-
Gauge
It shows where I fitted my probe :oops: from a simple thermometer. (don't know if this is the best place) Normally reads are around 100 deg, going up to 115-119 deg when the engines working hard :wink: :oops: :lol: .
ボンゴの激怒 pictures
helen&tony
TM2 engine watchdog
Post by helen&tony » Wed Oct 24, 2007 5:05 pm
Thanks, Brora, that's about where i planned to put mine, but I'll drill a hole inthe engine casing (seat base) to put the wire through, as I'm sure to b****r up my wire connection to the sensor , lifting the seats up and down. My alarm "thingy" also has a connection for the oil pressure light sender....any idea where it is...I just looked, and my bongo is always parked in the shade, and i always manage to forget a lamp!!!!!
clogger
Post by clogger » Wed Oct 24, 2007 8:57 pm
if you connect it up to the oil sensor it is a constant very annoying beep until the engine is started,
i never bothered
Brown/white wire that exits a small white plastic plug/socket at the top /back of the alternator under the drivers/passengers/any seat you wish
somewhere in the general vicinity of the bongo
ECKY THUMP
the one true art form
helen&tony
TM2 engine watchdog
Post by helen&tony » Wed Oct 24, 2007 9:07 pm
Hi Clogger
Many thanks, I'll probably try it and do as you have, and disconnect it if it's that bad!!!Isn't the alternator on the passenger's side?
haydn callow
Post by haydn callow » Wed Oct 24, 2007 9:10 pm
I put a switch in my oil alarm wire so I can turn it off till the engine is started. You never know it may go off one day and perhaps not notice the oil light. Mind you I expect by the time it goes off it would be damage done.
http://www.coolantalarm.co.uk
Also BMW Clocks
helen&tony
TM2 engine watchdog
Post by helen&tony » Wed Oct 24, 2007 9:21 pm
MMM...nice idea Haydn
haydn callow
Post by haydn callow » Wed Oct 24, 2007 9:32 pm
Yep !! alternator under passenger seat.
Also BMW Clocks
helen&tony
TM2 engine watchdog
Post by helen&tony » Thu Oct 25, 2007 4:23 am
Thanks Haydn
"Jolly Dee", I'll be doing that over the weekend
clogger
Post by clogger » Fri Nov 23, 2007 1:40 pm
hi peeps
one member has asked me where i mounted my tm2 temp guage so
here it is for all to see.
[Image
ECKY THUMP
haydn callow
Post by haydn callow » Fri Nov 23, 2007 1:43 pm
I've fitted mine in the little "cubby" hole in my BMW clock. Perfect fit.
Also BMW Clocks
helen&tony
TM2
Post by helen&tony » Fri Nov 23, 2007 2:08 pm
Ahh
I've mounted mine in the BMW clock cubby, but whereabouts did you bolt the temperature sensor....I'd be interested in your various readings , folks.
clogger
Post by clogger » Fri Nov 23, 2007 2:17 pm
the good old turbo timer lives in the bmw clock cubby hole and claimed squatters rights :D
i have the sensor mounted passenger side of the engine 2nd pre drilled/tapped hole down on the actual cylinder head
summer readings were up to 110c
cooler weather on the same stretch where it normally reaches 110c
last week it was 98c
ECKY THUMP
helen&tony
TM2
Post by helen&tony » Fri Nov 23, 2007 2:46 pm
Hi Cloger
I've fitted mine under the 1st. rocker cover bolt on passenger side. It reads around 40 - 50 on a run, and 75 in a traffic queue (not frequent here). I suspect there is a cooling draught coming up from air passing the belly mounted fan assembly, keeping the reading low.
Post by mikeonb4c » Fri Nov 23, 2007 2:53 pm
I begin to wonder how one turns this device into a reliable engine protector. Do you wait for the first head warping event then set the potentiometer (or whatever) to slightly below that temperature ready for next time :?
Seriously though - can anyone enlighten me
Gotta say though, the low coolant alarm is a no brainer and is a major cause of my relaxed attitude to life these days - better than Prozac. 8)
