Anti-freeze
maxheadroom
Anti-freeze
Post by maxheadroom » Thu Nov 08, 2007 10:30 pm
How much should I buy, as I'm going to change the thermostat?
Cheers all :lol:
Keep the Faith
Post by Bob » Thu Nov 08, 2007 11:19 pm
You could get away with zero if yours is in good condition and you drain it into a container and re-use it, otherwise 50% mix.
Post by missfixit70 » Thu Nov 08, 2007 11:23 pm
50% is overkill, 5 litres should do it, that gives you just over 33% mix with a bit of spillage allowance (13.5 litres coolant capacity).
Post by bigdaddycain » Thu Nov 08, 2007 11:38 pm
Could you clarify please Kirsty? Why is 50% overkill?
maxheadroom
Post by maxheadroom » Fri Nov 09, 2007 9:33 am
5 liters it is then, thanks all
Keep the Faith
