Dicky petrol guage
tykeboyuk
Dicky petrol guage
Post by tykeboyuk » Thu Oct 25, 2007 9:19 pm
I have read the posting re petrol guage problems but don't know how to get at (or even see!!) the little plastic thingy that I need to fix/improve earthing.
Can anyone help?
David Edwards
Post by David Edwards » Thu Oct 25, 2007 9:35 pm
Loads of stuff on here about it, rear seats back all the way, middle forward all the way, rip up carpet (strength needed) unscrew cover disconnect and clean contacts, drill 2nd hole, attach wire with screw to bare metal as 2nd backup earth, replace everything. There.
tykeboyuk
Dicky petrol guage
Post by tykeboyuk » Thu Oct 25, 2007 9:41 pm
Cheers David. Will have a tinker at the weekend
dandywarhol
Post by dandywarhol » Fri Oct 26, 2007 12:29 am
I did one the other day - same procedure to get to it as David says.
To establish that the fault lies in the sender not the gauge, remove the plastic wiring connector from the sender, take a piece of electrical cable, strip the ends about 1/2 inch, and put one end of the cable into the cable which isn't black (forgotton the colour of it) and the other to a good earth. Switch on the "ignition" and if the fuel gauge goes up to full then the fault lies in the sender/or earth.
I then stuffed the bared end of electrical cable into the BLACK cable going to the sender and refitted the plastic connector to the sender unit. I then fitted a small "O" electrical connector to the other end of the "new earth cable" and secured it under one of the sender unit cros headed screws.
The job's a carrot - gauge working :D
maxheadroom
Post by maxheadroom » Fri Oct 26, 2007 6:30 am
tykeboyuk,
loads of info here, I hope it helps
http://www.igmaynard.co.uk/bongo/forum/ ... highlight=
Keep the Faith
tykeboyuk
Post by tykeboyuk » Fri Oct 26, 2007 5:28 pm
Hi all
Many many thanks to all. Now working...and I thought I only had a 30L tank as it used to go from full to empty in no time!
Post by mikeonb4c » Fri Oct 26, 2007 10:04 pm
Wow - quick result. Great news. Weather forecast crap with weekend for driving. Not great news 8)
David Edwards
Post by David Edwards » Fri Oct 26, 2007 10:39 pm
No no no, I am off to Devon tomorrow for a week and I have spoken with the great pumpkin and the jeebers guy and been promised a week of fine weather. Besides my dragons are shedding scales and they never do that if its gonna rain, gets very damp in the caves complex see,. :lol: So it has to be fine.
