The narrow chrome trim on the trailing edge of the passenger door is loose for about the top 15 inches (where all the changes in direction are). Any suggestions for the best glue to use and also how the devil to hold it in place while said glue takes hold!
Ron
chrome trim loose on passenger door
- Tribal Elder
The best glue type of glue to use would be a contact adhesive - something like Evo Stick and the best thing to hold it in place whilst it goes off would be masking tape or insulation tape as they won`t mark your paintwork. Hope this helps .
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Thanks kawasaki - I'll get some evostick and try it
Ron
Ron
Thanks smartmonkey for your comments. Here is a pic showing the trim in question
Ron
http://www.livejazzuk.co.uk/loosetrim 001.jpg
( and if you remove the file name at the end you can listen to some jazz too!)
Ron
