No need to check the voltages, I was just curious as to what the mystery ticking sound is that occurs in that voltage range.
I've had a couple of pm's from 2sticks and his makes the same noise. He measured his TSCR too and got a value of 1975 Ohms. That means that all our resistors are out of spec with the published value by a factor of 1000.
I'd say that makes it's official, there must be a typo in the manual.
I think is should read:
throttle sensor compensation resistor should be 0.1 ~ 2.5 kOhms.
BTW did you find the TPS values that you asked for in that other thread (Economy, maybe a good mod or two.) in the performance section. They're the published reference values not readings I've taken.
Thanks for taking the time to measure things for me guys, much appreciated
