oil on nearside front wheelarch
just spotted some oil on the inside of the front wheelarch, on closer inspection it seem to be coming from the drive sharft at the wheel end, is this a common problem and is it an easy fix as i am going away in her next week, any advice greatly appreciated, lee
- Tribal Elder
Hi, Sounds like a split gaitor as I had the same thing when mine went, managed to seperate the shaft from the cv fairly easy and changed gaitor but when the other side split couldn`t seperate the shaft so rebuilt suspension and put a polly bag around gaitor to keep lube in and dirt out so as not to wreck the cv joint. Don`t cut off the old gaitor until youv`e seperated the shaft because if it`s seized at least you can use the van until you can get it sorted like I did. The gaitors seem to split due to an age and standing around whilst being imported problem. Hope this helps. Ian.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
