Help needed from the BFPS
just finished work and had alook at the bolt in the carpack then came on here to give you the info but someone beat me too it, not to worry as long as you got the info thats all that counts hope you get it fitted ok, i use mine pointing upwards to store my map books as the make an ideal place and are easy to reach
I've got a towbar but have managed to come a cropper twice nonethless. First time wold have happened to anyone (and the campsite reception confrmed it had happended to many) when a low, sharp rock placed out of site just where you reverse out of the campsite pitch got the left hand rear corner badly.
then 2 wks ago - my fault for being too polite - I reversed back hastily to make space for an elderly couple to pass side by side on the pavement (it was one of those bad roads where you have to put 2 wheels on the pavement). I didnt see the lamppost in the rear door piller blind spot and when straight into it. Same place as previous but this time dinged the metal on the tailgate. V p*ssed off. I must fit sensors but havent found time yet.
