Help needed from the BFPS
Hi all
I've now got a footrest from Little Movers, but they always put the bolts back in the van - does anybody know the size of bolt required to fit my seat/footrest?
- Peg leg Pete
Ta Pete, but the threads in the Bongo and I couldn't get it through the doorPeg leg Pete wrote:Franco take the footrest to a engineers merchant, they will tell you the thread size, plus some vehicles use metric fine threads
- Peg leg Pete
- Peg leg Pete
Ok folks here we go. The original bolts are actually a thread cutting screw. However an 8mm 1.25mm pitch bolt is fine (I tried it) You will need a bolt that has 25mm of thread under the head. You will also need a flat washer of 15-20mm diameter. If you pm me I'll post some tomorrow, got thousands at work!
- Peg leg Pete
