Help rear view mirror
Please help
My rear view mirror fell off the other day?
Can anyone tell me where I might get a replacement. The bit is still attached to the windscreen - the joint holding the actual mirror on broke.
Please help as it would be nice to see out the back again
Compobongo
Compobongo
Are you talking about the mirror in the car on the windscreen or the one outside at the back?
You could try Bellhill or Bongo bits, both of which advertise on the BF site. If it is the front windscreen mirror then any mirror thats sticks to the windscreen (new sticky pads required from accessory shop) could be bought from a scrap yard.
- Peg leg Pete
- Peg leg Pete
- Tribal Elder
If you can get to a breakers yard any rear view mirror from a Mazda of around the same age should do the job and look like the original for just a few pounds and the cost of the self adhesive pad for the windscreen.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
- Tribal Elder
Just a follow up to my previous message be very careful taking the old mirror off your windscreen if there is any of it left on as you could crack the windscreen if you use to much force
. That would be expensive.
Nice try Pete, thanks. Mind you I might as well take the front one off as well for all I can see out of the back.Peg leg Pete wrote:Check out thread on bongo chat, lovejoy is thinking of removing his mirror
Tend not to use it much anyway as I drive my baby van most of the time and that has no view out of the rear, so I tend to forget the mirror's there.
