water leak
				andy caff
water leak
hope someone can point me in the right direction,ive been losing coolent and spotted water dripping from the engine guard thing under bongo,removed plastic engine guard thing and can only see water comming from behind pulley wheels had torch out but cannot see anything any help would be much appreciated. thanks
						- haydn callow
				andy caff
- haydn callow
Take the belts off and see if there is any side play on the shaft. If there is any it needs a new pump. If not see if the seal around the pump housing is leaking, If it is take off the pump and make a new gasket and refit.
Most likely the shaft co's people tend to overtighten belts to get rid of squeal, instead of replacing belts.
				ParkerNorris
 - Bongonaut
