Starting problem
Bon go north
Starting problem
Post by Bon go north » Sun Mar 04, 2007 10:44 am
Since yesterday my Bongo has had trouble firing up. When I turn the key it seems as if there is no power and it just runs out. When tried again, blipping the accelerator fired it up, no problems running when started and no warning lights on the dash.
Any ideas anyone?
Andy
Post by mikeonb4c » Sun Mar 04, 2007 11:17 am
You'll get better advice from someone more techie than me, but there is lots of previous stuff on subjects like this. Try entering 'glow' in Search to get threads on glow plug problems with starting (or glow plug relay). Then maybe 'fuel AND filter' to see if its anything like blocakge causing fuel starvation. Good luck - I'll watch this thread out of interest too in case it happens to me - and don't panic, it may well be something 'routine' and easily fixed!
best
Mike
Post by francophile1947 » Sun Mar 04, 2007 12:03 pm
Hi Andy
Sounds like your glowplugs are failing as it runs OK once started.
Dabs
Post by Dabs » Sun Mar 04, 2007 12:04 pm
Good advice Mike!
Dont panic,is it under warranty Bon Go North if it is take it back!
Dabs
Bon go north
Woohoo
Post by Bon go north » Sun Mar 04, 2007 4:19 pm
Got my batteries checked at the local halfords.
They were supposed to be putting out 560 Amps. 1 was 230 and 1 313.
Batteries changed problem solved
cheers
Dabs
Post by Dabs » Sun Mar 04, 2007 5:52 pm
BGN
Glad You are sorted!
Dabs
Post by mikeonb4c » Sun Mar 04, 2007 7:13 pm
Excellent - happy motoring! 8)
Gemtps
Post by Gemtps » Mon Mar 05, 2007 9:27 am
I've had a starting problem since I picked mine up and am still waiting for the garage to call me back in to repair it.
It's intermittent and very very odd.
Sometimes it starts first time (but then the electric window won't work or one of the blinds) or it won't start but everything else works. It just clicks - all the lights come on ok, it just doesn't turn over at all.
It must be electrical I guess.
ebygum32
Post by ebygum32 » Mon Mar 05, 2007 9:42 am
filled up at tescos or morrisons recently
Post by mikeonb4c » Mon Mar 05, 2007 9:58 am
You jesting ebygum? - unless gempts has a petrol V6 Bongo :lol:
Interested to hear what it turns out to be gempts. You've not upset it with too much pink have you 8)
Gemtps
Post by Gemtps » Mon Mar 05, 2007 10:30 am
mikeonb4c wrote:You jesting ebygum? - unless gempts has a petrol V6 Bongo :lol:
Hahahaha !!! I hope not. :D
It's getting worse though - it's almost every time I start up now whereas before it was only once or twice a week. Very frustrating.
And no, I'm not petrol thank goodness !!! :wink:
Post by francophile1947 » Mon Mar 05, 2007 1:06 pm
Hi Gemtps
Be interesting to see the outcome of this, especially as the blinds and windows are different circuits. :? :? :?
Post by mikeonb4c » Mon Mar 05, 2007 2:49 pm
Also Gemtps - arent you still under guarantee from the dealer?
wrster
Post by wrster » Mon Mar 05, 2007 3:03 pm
When it clicks and the starter doesn't even try to turn, it usually means the contacts/brushes in the starter are on their way out.
You can get the starter overhauled for around £100.
Mines started doing this, the age old solution is to tap the back end of the starter motor (under driver seat on side of the engine) with a hammer. The shock normally gets the contacts working again. Though you'll still need to get it overhauled.
How this relates to your other electrical gremlins I don't know.
You could do a search on 'starter' to get some historics on the issue.
vic swan
Post by vic swan » Mon Mar 05, 2007 3:05 pm
Could possibly be a starter motor problem. Apparently the terminals on the solenoid get worn and cause intermittant connection trouble. I had this, just got progressively worse. Picture the wife and I jumping up and down on the seats until she started. (The Bongo that is). :roll: New starter cost me £200 including fitting, it was new, not reconditioned. Shop around, because there is a big differance in prices out there. :)
