just got our bongo and seen that the engine is under the passenger seat. Can anyone tell me whats under the driver seat
cheers
drivers seat
Re: drivers seat
...the other half of the engineriggy wrote:just got our bongo and seen that the engine is under the passenger seat. Can anyone tell me whats under the driver seat
cheers
- Peg leg Pete
The first time You have a gander under the seats is a real voyage of discovery,and a strange place to be after owning a more ordinary car.Check all the hoses especially when the engine is hot as it seems to be then when any pinprick holes in the hoses open up.Speaking from experience it toom Me two weeks to trace the tiniest of coolant leaks down to a pinprick hole in the bleed pipe,I knew I had a leak but couldnt figure out where it was coming from but I was checking when the engine was not at full operating temperature,it did not leak when cold it only leaked when hot.Its sorted now but its left me obsessed with checking coolant levels etc.Not a bad thing with a Bongo
Good Luck with the new mota Riggy and ENJOY
Dabs
Dabs
