Common problem on a Bongo (apparantly!!)
- dandywarhol
This is a common problem on a Bongo according to the bumf and pic on Fleabay..............
anyone elses like this????
- dandywarhol
Ouch! that looks nasty!
I hope I dont have nightmares after seeing such a sight!
I'm a collector of random things. Anything. But not glitter, which is nasty.
www.random-things.co.uk
NOpe never had anyone take a bite out of mine like that, I have however, seen something almost similar on a Renault Espace ( plastic body I have owned two), that was caused by something that more and more people are buying, namely a Karcher or similar pressure washer. |I have one myself but would never wash the car with it, the pressure is just too much and cars were never designed to be washed by em, the slightest blemish and... woosh... goodbye paintwork. This can be alleviated ( big word I know) by regularly hosing out the wheelarches, something the average motorist does not think about ( no insult intended) but which is something that used to be drummed into us on driving courses where the vehicle is washed after every trip can help prevent it, that and a good sloshing with underseal. Happy motoring.
Nope...never seen anything like that before....checked mine tonight...no corrosion under there at all...and it isn't undersealed.
I do make a point however of washing down under the wheel arches most weeks, particularly in winter, having had trouble with other vehicles rusting here.
If thats a sample of the bodywork, goodness knows what else is going on out of sight.....wouldn't touch this bongo with a barge pole.
cheers
H
cheers
H
This is a word of warning. Those that get a pressure washer, can go mad, not knowing the damage that it can cause. If you do own a pressure washer, use it with chopsticks. The first time, it can be a case of mnnnn... look how clean I am washing... but then you realise what you have power washed off !! and it's not pretty i tell you...like the jumper i received for christmas!namely a Karcher or similar pressure washer.
Hey guys, if you were having a bath with your loved one, you wouldn't hose her down wit ha Karcher would you. No, you'd take a nice soft sponge and some skincare soap and gently sponge her all over. Then, it a fit of playfulness, you might take the shower head and wash all the soapy water off with it. I dont think I can stretch the comparison further than that
