Page 1 of 2
Posted: Sun Feb 11, 2007 5:26 pm
by Ozric
I don't know if mine was a default one, but you may need to insert some rods into the holes on the front. This releases clips inside. You can make your own with a wire coat hanger.
Cut 4, 5inch lengths from the coat hanger and bend half an inch at the end.
Insert the into the 4 holes at the same time and pull the stereo. If you push the rods in too far you won't be able to get it out, so it takes a bit of messing about with.
Posted: Sun Feb 11, 2007 6:14 pm
by trevd01
Wire coathanger works for many radios (DIN fitting):
Here are some other removal tools:
http://tinyurl.com/2n8qve
Posted: Sun Feb 11, 2007 6:56 pm
by NeilT
ta for the advice... will try a floppy mop in the morning...
Posted: Sun Feb 11, 2007 6:59 pm
by clogger
a lump hammer
by haydn callow
I had to remove the glovebox (easy it just pulls out with a bit of squeezing) Then get your little pinkies in behind the radio and you may find a screw/bolt sticks out from the back of the radio and through a metal mounting frame. I couldn't get at it well enough with my fingers so I leavered it out with a large screwdriver, no damage co's it is all held together with a rubber grommet. Have a feel round and see.
Posted: Sun Feb 11, 2007 7:48 pm
by francophile1947
Mine needed 2 bits of flat metal to push down each side of the radio/cassette. This pushed the springy bits of the casing in and allowed it to slide out.
Posted: Sun Feb 11, 2007 8:45 pm
by etihsbog
Me and a couple of the boys could come round and we would have it out before you could unlock the door
While there we could also remove them ugly 19" alloys, and leave you on a lovely set of bricks, only 2 previous owners
Posted: Mon Feb 12, 2007 12:49 am
by dandywarhol
etihsbog wrote:Me and a couple of the boys could come round and we would have it out before you could unlock the door
Where is it you're from again etihsbog???.............oh yes, I remember seeing it in your avatar
Posted: Tue Feb 13, 2007 4:46 pm
by NeilT
Got the radio out
used 2 small alan keys, to poke in the holes, and out came the radio... Now waiting for delivery of my new one, a remarkable one for under £5000.00 !!! plays MPS, also usb hub, so hope to fit a 40 gig hard drive in the dash
and takes SD memory cards
http://www.ebuyer.com/UK/product/104104/rb/25211946806
Got to wait 500 days for delivery.....
Posted: Tue Feb 13, 2007 5:18 pm
by trevd01
Get one like this:
http://tinyurl.com/2qmtbe
£25, and it gets its power from the USB, no messing about with a 12v power supply for the hard disk.
Bought one recently to backup critical data on the old laptop.
Same vendor has bigger ones too 100gig £45
Posted: Tue Feb 13, 2007 5:24 pm
by Ozric
Word of warning.
Not all stereos work with USB harddrives. Some are even fussy over the type of USB memory stick. I'd wait until you have the stereo and check what it accepts.
Posted: Tue Feb 13, 2007 11:30 pm
Stereo seems a great price NeilT - look forward to hearing your review of it once fitted. On the 40Gb USB disk thing, how are all the playlists and stuff managed if you just stuff a large disk with loads on MP3 into the USB
Posted: Wed Feb 14, 2007 12:30 am
by NeilT
I have a USB powered 4 gig hard drive, had a freind that was bulding them long before they came on e-bay
As mentioned here, till I have the unit installed it is going to be hard to say how it will work, but most MP3 "players" will look for the folders where you you then have the tracks.
If the hard dive does not work, the the SD card should, have ordered 2 2gig cards, each one will hold around 3 tubs.... Oh, I do like my golden wonder potted snacks
Posted: Wed Feb 14, 2007 1:01 am
by francophile1947
Hi Neil
That's the first time I've seen that make since I bought one of their DVD recorders with a 250Gb hard drive. It has performed well so I think you will be happy with it.
Posted: Wed Feb 21, 2007 1:17 am
by NeilT
Just to feed back on this my CD player came this morning
http://www.ebuyer.com/UK/product/104104/rb/25211946806 All I can say is Chees & onion crisps!! Installed dead easy with the plug adaptor , looks good, sound great, and am well chuffed... if you can wait a decade for delivery the postage is also free
also got some i gig SD cards, now loaded with MP3's all working great, a 1 ig USB stick, also loaded... not tried my 4 gig hard drive, but will try it yesterday..
Anyone looking for a CD player, that is just packed with features, and for less than £5000.00 this is the mops flops!
