Radio Removal - Is there an easy way?
I don't know if mine was a default one, but you may need to insert some rods into the holes on the front. This releases clips inside. You can make your own with a wire coat hanger.
Cut 4, 5inch lengths from the coat hanger and bend half an inch at the end.
Insert the into the 4 holes at the same time and pull the stereo. If you push the rods in too far you won't be able to get it out, so it takes a bit of messing about with.
Wire coathanger works for many radios (DIN fitting):
Here are some other removal tools:
http://tinyurl.com/2n8qve
- haydn callow
I had to remove the glovebox (easy it just pulls out with a bit of squeezing) Then get your little pinkies in behind the radio and you may find a screw/bolt sticks out from the back of the radio and through a metal mounting frame. I couldn't get at it well enough with my fingers so I leavered it out with a large screwdriver, no damage co's it is all held together with a rubber grommet. Have a feel round and see.
- dandywarhol
Where is it you're from again etihsbog???.............oh yes, I remember seeing it in your avataretihsbog wrote:Me and a couple of the boys could come round and we would have it out before you could unlock the door
While there we could also remove them ugly 19" alloys, and leave you on a lovely set of bricks, only 2 previous owners
Got the radio out
used 2 small alan keys, to poke in the holes, and out came the radio... Now waiting for delivery of my new one, a remarkable one for under £5000.00 !!! plays MPS, also usb hub, so hope to fit a 40 gig hard drive in the dash
and takes SD memory cards
http://www.ebuyer.com/UK/product/104104/rb/25211946806
Got to wait 500 days for delivery.....
Get one like this:
http://tinyurl.com/2qmtbe
£25, and it gets its power from the USB, no messing about with a 12v power supply for the hard disk.
Bought one recently to backup critical data on the old laptop.
Same vendor has bigger ones too 100gig £45
I have a USB powered 4 gig hard drive, had a freind that was bulding them long before they came on e-bay
As mentioned here, till I have the unit installed it is going to be hard to say how it will work, but most MP3 "players" will look for the folders where you you then have the tracks.
If the hard dive does not work, the the SD card should, have ordered 2 2gig cards, each one will hold around 3 tubs.... Oh, I do like my golden wonder potted snacks
Just to feed back on this my CD player came this morning
http://www.ebuyer.com/UK/product/104104/rb/25211946806 All I can say is Chees & onion crisps!! Installed dead easy with the plug adaptor , looks good, sound great, and am well chuffed... if you can wait a decade for delivery the postage is also free
also got some i gig SD cards, now loaded with MP3's all working great, a 1 ig USB stick, also loaded... not tried my 4 gig hard drive, but will try it yesterday..
Anyone looking for a CD player, that is just packed with features, and for less than £5000.00 this is the mops flops!
