Window switch faulty
Going to have to sort this out. Does the switch simply prise out or is there something else I should know ?
It prises out with a small screwdriver blade. Be careful not to damage the trim. Strip it down and clean it up. You may be able to improvise and make good any worn bits of plastic to make the contacts work again. They really are a cheap and crap job these switches so go carefully. Watch out for the spring under the window lock button.
It's worth the trouble trying to fix it as people are asking silly money for replacements. £115 new and £45 upwards used.
Cant help re the fault switch, but when they are loose in the door card it is usually due to the front clip having snapped as it is only plastic. If you are levering them out then lift the rear end first and be gentle. If the front clip is broken you can quite easily bed a piece of aluminium to reform a suitable retaining clip.
On the subject of second hand ones, I would only buy from a breaker who has other parts for sale. Some ebayers make a fortune out of these by stealing them from Bongo's at the auctions. Its fairly obvious who they are if you check their listings - no point fueling their greed.
Rant over.
Rant over.
electrical switches and things
The electrical switches and things seem to share a lot of their components with Mitsubishi parts- I believe the window switch unit is readily replaceable with old mitsubishi galant/sigma equipment. or at least something could be fashioned between the two units- worth havinga look round a breakers yard if at all possible.
I say, Do You Bongo?....... RATHER!
I suppose people have checked that switches from Mazdas of the same era (626, 323, MX5 etc) or even a Ford Probe don't fit?Veg_Ian wrote:Good idea Mike but I've already trawled through ebay listings and nothing comes close. Pity because you can pick BMW and Jaguar ones up for less than 25 quid, Toyota ones for less than a tenner. Crazy world eh?
Spent a couple of hours in my mates scrap yard this morning removing switches from most cars that looked similar and couldnt find anything that would easily convert. Problem seems to be that the bongo uses a sliding switch mechanism inside whereas everything else uses microswitches.
smoke me a kipper i'll be back for breakfast
