Rear door handle
dandywarhol
Rear door handle
Post by dandywarhol » Thu Feb 08, 2007 10:18 am
I've done a search (and used "and" between the words :wink: ) and can't find any info on removing the tailgate door external handle.
Can it be removed from the outside or do I have to remove the inside panel?
gazz and ally
Post by gazz and ally » Thu Feb 08, 2007 10:20 pm
Dandy - do you mean the 2 handles on the exterior of the tailgate either side of the reg plate? If so, then you simply pop oen the plastic tabs carefully with a flat screwdriver and undo the crosshead screws underneath. If not, what do you mean...? Gazz
