Fuel Injection Pump
pyroman
Fuel Injection Pump
Post by pyroman » Tue Jan 23, 2007 10:27 pm
Does anyone have photos/diagrams or data sheets of the fuel injection pump for 2.5Turbo Diesel Bongo?
Thank you in advance,
Pyroman
silvergecko
pump
Post by silvergecko » Tue Jan 23, 2007 11:03 pm
hi have problems with my pump. whats wrong with yours?
pyroman
Fuel Injection Pump
Post by pyroman » Wed Jan 24, 2007 8:21 pm
I have had problems for a few weeks now, where she stutters when I am at lights or on the drive. Checked all filters etc, glowplugs. Eventually noticed fuel dripping from the pump area but not quite pinpointed exactly where it is from. So I thought that when I have a closer look, some photos or diagrams might help to orientate me.
silvergecko
pump
Post by silvergecko » Wed Jan 24, 2007 9:39 pm
i have same leak i will take some photos and try and put them on but will have to be weekend as bongo with diesel specialist at moment they think pump has fault inside and they havent even noticed the leak some specialist?
antique
leak
Post by antique » Thu Jan 25, 2007 10:05 am
silvergecko put it this way over the years, i have taught my self how to fix a lot of probs with bongos , because of what you a just said, we have fixed all leaks on pumps , yes it cost to learn ? i have a spare pump will take some pics of the seals that leak,
phil 1
Post by phil 1 » Thu Jan 25, 2007 7:37 pm
Hi I appear to have a leaking injector pump as well, I think it’s leaking from the back of the pump where the injector pipes come out is there a gasket around that area? I have only had a quick look at lunch time today will have a better look at the weekend. Any help and advice would be great.
antique
LEAK
Post by antique » Thu Jan 25, 2007 7:53 pm
hi yes there is a gasket on end of pump, but is more likely to be the plates on stop valve, i am going to get my spare pump back tomorrow ,will take some pics to make it easy.
silvergecko
pump
Post by silvergecko » Thu Jan 25, 2007 9:14 pm
think fault found :lol: garage phoned today and said problem in fual tank. appparently tank has dent in it and feed pipe not letting enough diesel through under pressure so new tank should put it right or second hand one :lol: :lol: :lol: :lol:
dandywarhol
Post by dandywarhol » Thu Jan 25, 2007 9:16 pm
Good one silver.............maybe try a big drain cleaning sucker to pull the tank back.......... :-k
pyroman
Pump Photos
Post by pyroman » Thu Jan 25, 2007 9:31 pm
To have the photos would be great, I think a few of us may have exactly the same problems, I would hate to spend several hundred pounds on something I could have sorted myself.
It is great that so many of you are here to help and share your experiences, I don't think there are many vehicles with such support from fellow users.
Post by haydn callow » Thu Jan 25, 2007 9:59 pm
Dandywarhol, Would a drain sucker such a dent out of a body panel? spec't it's worth a try. What do you call big?
Post by francophile1947 » Thu Jan 25, 2007 10:14 pm
hcallow
Just a sink plunger from hardware shops may do the trick.
dandywarhol
Post by dandywarhol » Thu Jan 25, 2007 11:34 pm
francophile1947 wrote:hcallow
:oops: that's what I meant - having a bit of a problem forming sentences tonight........
http://www.bizrate.co.uk/carrepairtools ... anels.html
Bumbly1
Post by Bumbly1 » Thu Jan 25, 2007 11:52 pm
Nothing new there then.... :lol:
antique
leak
Post by antique » Fri Jan 26, 2007 1:44 pm
hi i have taken pics of pump sent them to ian ,dont no how to put them on ? if any body wants to email me for pics off pump with seals off and back on ? [email protected]. thanks
