tap tap tap
AndAndDen
tap tap tap
Post by AndAndDen » Thu Dec 21, 2006 8:10 pm
Hi everyone. I need some imformation please, when i turn left or right i get like a slow tapping noise or if you like a rattle at the front end, sounds like its coming from under the wheel arches [its not very noisy] anyway took it for a run turned full circle left and right a few times everything seems to be ok no noise at all and also it seems to be more so when i'me turning left and its not happening all the time. Once again would appreciate some advise.Many thanks andy. :?
Post by Ian » Thu Dec 21, 2006 8:20 pm
Sounds like you need to replace your CV joints, or at the very least the boots.
AndAndDen
cv
Post by AndAndDen » Thu Dec 21, 2006 9:20 pm
Thanks Ian for the info, what i cant understand is that when i've turned full circle both ways a few times i dont get any noise at all, thanks again andy. :?
dandywarhol
Post by dandywarhol » Thu Dec 21, 2006 11:28 pm
Probably forced a bit of grease into the worn CV track - it'll soon knock again.......... :(
