When to replace brake pads
How thin can I allow a brake pad to become before it should be replaced?
Re: When to replace brake pads
Perhaps it depends how often you inspect them, it also depends how hard you drive! If you inspect them regularly then you can take more chances but it is a gamble I would not recommend.parabat2 wrote:How thin can I allow a brake pad to become before it should be replaced?
Reminds me of a story from a book "Funny Amusing, Funny Amazing"
A driving instructor was in the habit of quoting poems while teaching. Pupil drives around corner and the instructor yells "brake! brake! brake!".
"Even I know that one - 'On thy cold gray stones, O Sea!'" just as they drove into the back of a truck.
Er um - the last time I worked on car brakes they were drum brakes. I've never worked on disc brakes at all but I gather they are easier. My quick questions are:
1) How can you check to see if your disc pads are worn / what the state of them is
2) Is it a simple DIY job to change them yourself?
Grateful if anyone can help and/or if there is a fact sheet or thread that can help (just looked and couldnt see one, but it is late!)
Cheers peeps
Cheers peeps
You can check to see if the pads are worn by jacking the van up and removing the wheel, you should be able to see the pads and how much wear is left in them. The calipers are held on by two bolts, it`s a simple job to remove them and change the pads. Just recently checked my brake pads and replaced the rear ones, the most time consuming part was jacking the van up!
There is also a fact sheet with more details.
Cheers.
Cheers.
i think my bongo pads had the "rattlers" i replaced them, however the replacement pads wouldn,t accept the "anti squeak shim" i just copper greased the backplates thoroughly, didn't work though, they squeal like a banshee when hot now! They work well though.
a little tip
When I replace my brake pads I push the pistons back with a G clamp I check the fluid reservoir to make sure it does not overflow. If it is too full I use a small shringe that I got with a ink cartridge kit to draw it out.
After fitting pump the pedal to push the pads out but only pump a little not full strokes. Some people are unfortunate and find that the master cylinder fails if they pump hard as the seals move down past the normal operating patch. Check that the brake is not dragging other wise you will wear out the pads. Rotate the disc without the pads to assess the drag of the drive. If you are changing the rear pads why not ckeck the hand brake shoes at the same time?
