Sticky front brake.
Bozo with a Bongo
Sticky front brake.
Post by Bozo with a Bongo » Fri Dec 15, 2006 1:55 am
Evening,all,my ,95 Bongo has got a sticky front o/s brake caliper,which gets very hot sometimes.Does anybody know where i can get a piston and seal repair kit.Have cleaned and coppersliped pads but still sticks. Love to all AW.
Veg_Ian
Post by Veg_Ian » Fri Dec 15, 2006 8:19 am
Bongobits?
Bingabanga
sticky brake
Post by Bingabanga » Fri Dec 15, 2006 4:23 pm
I once had this problem in fact the brake on a chevy got so hot the grease melted and smoke came from the wheel . Panic!! thought it was the bearing but it was the flexible hose breaking up inside and acting as a one way valve and holding the brake pads on!! easily solved. Might be worth just keeping in the back of your mind? Always have somehting to worry about :lol:
Bozo with a Bongo
Sticky brakes
Post by Bozo with a Bongo » Sat Dec 16, 2006 6:00 pm
:lol: Thanks gents,Turned out, one of the pistons was rusty,and knackered looking ,pulled back seal and put in brake fluid,worked in and out a few times.now freeing off allright.and working.I can now spend hours on the M5 this xmas worrying about the piston seals.Cheers AW.PS got the advise from Alans vehicle services.
bongolow
Post by bongolow » Sat Dec 16, 2006 9:39 pm
I had that trouble with my old Skoda and did the same trick with the brake fluid but eventually it dries out and you have to do it again.... and again. Keep an eye on it and if it does happen again I would bite the bullet and get the brake assembly re-furbished with new seals fitted.
