Steering wheel change
James j
Post by James j » Tue Sep 16, 2025 8:13 pm
I’ve my original bongo steering wheel which has separated. I’ve bought a mz6 steering wheel to replace it. I’ve had off the original steering wheel, the connecting rod has what I believe are called splines to fit the wheel on. The new wheel has a bolt shape hole. I’ve seen images of this wheel on a bongo. Has anyone any idea of the adapter bit required to get around this??
James j
Re: Steering wheel change
Post by James j » Tue Sep 16, 2025 8:17 pm
James j wrote: Tue Sep 16, 2025 8:13 pm I’ve my original bongo steering wheel which has separated. I’ve bought a mz6 steering wheel to replace it. I’ve had off the original steering wheel, the connecting rod has what I believe are called splines to fit the wheel on. The new wheel has a bolt shape hole. I’ve seen images of this wheel on a bongo. Has anyone any idea of the adapter bit required to get around this??
Post by Doone » Wed Sep 17, 2025 6:41 am
Theres some info in this post that might help: viewtopic.php?t=69147
