Bongo Making Loud Noise - Electric
Calisoul
Post by Calisoul » Sat Aug 30, 2025 4:40 pm
Hello people,
This morning I noticed the van making a horrible noise and it was completely off, I started it and it went around the block all fine but the sound kept on going, I disconnected the battery and it's stopped so I presume it's probably something electrical.
Video of the sound here:
https://www.dropbox.com/scl/fi/pyepg4db ... iyqxh&dl=0
Any help is much appreciated, I'll check the fuses to start tomorrow and it's a 1995 2.5L diesel.
Re: Bongo Making Loud Noise - Electric
Post by g8dhe » Sat Aug 30, 2025 5:25 pm
Sounds like a relay or magnetically controlled device which is having problems. You need to investigate under the bonnet, the dashboard etc to find out what device is causing the problem.
