wiring box has a squeaky rattle
BromGo
Post by BromGo » Tue Aug 05, 2025 2:28 pm
does anyone else's wiring box (near right-knee area of driver's side seat) make a (bloody annoying!) squeaky rattling type noise? I've tried tightening the screws but don't want to over-tighten. Might just wedge a sock in there to dampen it.
thought worth asking if anyone else has experienced this....
:lol:
Re: wiring box has a squeaky rattle
Post by g8dhe » Tue Aug 05, 2025 2:52 pm
A lot of people report a problem with a squeaky dashboard as being the supports for the big crash pad "pipe" 60-420B that supports the entire dashboard where they fix at each end. I believe you can gain some access by removing the end panels to get to the screws?
https://www.lushprojects.com/bongoparts ... mgno=.html
Bongolian
Post by Bongolian » Wed Aug 06, 2025 9:08 am
I’ve used a spray of ACF50 on ‘squeaky things’ in the past to good effect.
I use it quite a bit on my motorbikes for a variety of purposes, it bonds in a molecular way to prevent corrosion and provide lubrication, great at keeping your bike in good condition if you ride in all weathers.
It lasts quite well, and is not sticky or smelly, pretty good on black plastic trim (bumpers etc) restoring colour.
Just keep it away from your brake discs/pads 👍
https://www.sportsbikeshop.co.uk/motorc ... rod/339234
BromGo
Post by BromGo » Fri Sep 05, 2025 11:57 am
this is really doing my nut in. with or without plastic fascia over the wiring connector box it squeaks and squeals. shoving a sock in there did not help...
not sure how the bar could be the culprit; sound is localised to driver side right around the wiring. i'll see if i can make a video.
Post by g8dhe » Fri Sep 05, 2025 2:24 pm
What happens if you remove the fixing screws for the fuse panel just to give it a run and see what happens? Maybe a sliver of plastic bag around the edges if that really is the cause of the noise?
