misfire, not idling right
stancoppo
Post by stancoppo » Wed Jul 02, 2025 3:32 pm
my bongo friend is hard to start misfires and doesnt idle without stalling, any ideas? help?
Re: misfire, not idling right
Post by Doone » Wed Jul 02, 2025 5:11 pm
Which engine has it got?
stancoppo
Post by stancoppo » Tue Jul 08, 2025 9:58 pm
it is petrol 2.0 I suspect distributor after having new leads and distributor cap
Post by g8dhe » Tue Jul 08, 2025 10:13 pm
Its probably worth checking all aspects; Plugs clean and adjust gaps if required, leads make sure the leads and connectors are all clean and in good condition, then distributor cap and rotor, then finally the king lead and back to the spark coil again making sure there clean and in good condition.
stancoppo
Post by stancoppo » Fri Jul 11, 2025 6:52 pm
the distributor was changed but still the same problem. on this model there is no falt finder socket for computer as it is older model so we are just guessing
stancoppo
Post by stancoppo » Fri Jul 11, 2025 6:54 pm
its not misfiring but runs very rough and stalls without revs
Post by Doone » Sun Jul 13, 2025 6:17 pm
Common cause is a faulty mass airflow MAF. There are 2 types so you need to match the number sticker on yours.
stancoppo
Post by stancoppo » Thu Jul 17, 2025 9:21 pm
Hi Doone, changed mass airflow MAF, and still we are baffled, still looking for other options, might try and get some codes.
Return to “Devon & Cornwall/Kernow”
