Flashing Glow Plug Light - unable to diagnose
BaileyBongo
Post by BaileyBongo » Tue Jul 01, 2025 9:54 pm
Evening all, just got back from Glastonbury and have a bit of an issue with the Bongo.
We've had it before as well but I really want to sort it now as we've just had a new head gasket on it and loads of welding thanks to A&S Motors in Caerphilly South Wales to get out and do some further exploring in it.
Bailey is a 1999 model(according to the paperwork) but post 2001(from the model information sheet as it's KH-SGL5) 2.5TD 4WD AFT
Situation... the glow plugs seem to begin flashing after it's been driven for about 50 miles and it then becomes susceptible to stalling and a loss of power at low speed (traffic etc.). Meaning having to start again which is a laboured(and dangerous) when on the M5 yesterday but fine when driving at speeds and up at higher gears.
It does seem to happen more when the cigarette lighter is used to charge a phone and I've also noticed that the scavenger fan doesn't seem to be working (which I would have expected to kick in when on long journeys)
I have tried a few different things including cleaning the banjo filter, started using Millers Oil(but only used it once so far) and drilling a small hole in petrol cap(as that did seem to have a vacuum within it when unscrewed and we'd stopped)
I am struggling to diagnose it as the biggest issue is I am in no way a mechanic, but also..
  • If it is pre-99 it only comes on when driving for about 50 miles
  • If it is post-99 there doesn't seem to be any pattern or sequence to follow and just a steady on and off
It has a leisure battery fitted and that does seem to get pretty flat even when regularly plugged in to charging and even when I have attached a battery charger directly.
Any help would be greatly appreciated
gilly99
Re: Flashing Glow Plug Light - unable to diagnose
Post by gilly99 » Wed Jul 02, 2025 4:46 am
First step is to diagnose the problem. The members area gives details of how to connect into the ECU to trigger the diagnostic code sequence of the flashing glowplug dash warning light. It's easy, but be careful as the ECU is very expensive. The problem is unlikely to be the glow plugs themselves.
It sounds like you are going into limp mode after driving for a while - that's a fairly common issue (ie flashing glowplug warning light) and it's to protect the engine, but you need to find the source of problem.
One you have the diagnostic codes, then decipher them....
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Edit: sort the leisure battery problem first. Any sort of battery problems can play tricks with the ECU and trigger warnings.
WestyK
Post by WestyK » Wed Jul 02, 2025 10:16 am
I wonder if you are using a Swap loom to move devices like radio, cigarette lighters and interior lights to the leisure battery.
If you are this also moves some of the ECU power I believe. so if your Leisure batter is going flat that would cause all sorts of issues as Gilly99 says.
It sounds like your leisure battery may not be charging when the engine is running so I would test this with a multimeter first. You should see over 13.5v preferably higher but no higher than 14.4v when the engine is running.
If you don't see that then you have a fault with the split charge system. most likely just a blown fuse.
You may also fine the battery is on its last legs but check its charging first :-)
This may not be your issue but think its a good starting point as it needs to be checked anyway.
the only other thing I can think of that could cause an issue when warm is a faulty crank sensor or temp sensor but I wouldn't change these without checking the Leisure battery first.
by the way don't worry about the scavenger fan. It hardy ever runs on mine and think its only really designed to run when stuck in traffic for a long time so the engine bay gets some cool air. If your moving it wont come on. (in my experience at least)
Post by Ian » Wed Jul 02, 2025 12:10 pm
To establish whether your Bongo is pre or post 99, let us know the 6 digits after SGL5. This will be the full chassis number and we can determine the manufacture date.
BaileyBongo
Post by BaileyBongo » Wed Jul 02, 2025 7:09 pm
gilly99 - Thanks, multimeter on the way so that'll be something for the weekend. Try and diagnose the issue
WeskyK - The leisure battery does power what you mentioned and it went flat before(I think when it was in the garage and having quite a bit of work) and I fully charged it back and then came radio etc.
I have fully charged it now and fully charging the main battery as well, the relay(I think that's what it is anyway) has a permanent green light on as it's charging.
Again, something to try when multimeter is here.
Ian - 400011 is the number.
Post by g8dhe » Wed Jul 02, 2025 9:54 pm
When the LB goes flat (or disconnected) the ECU looses its settings and hence when the LB is recharged the ECU reports the error but there is no code for it as its loss of power! In that situation take it for a run and then the second time of starting it should be fine. However this type of problem above doesn't match the original report as the error lamp started flashing after 50 miles or so, that will be something else which can be read from the diagnostics panel.
Post by Ian » Thu Jul 03, 2025 7:40 am
BaileyBongo wrote: Wed Jul 02, 2025 7:09 pmIan - 400011 is the number.
You are a post-99 Bongo
BaileyBongo
Post by BaileyBongo » Thu Jul 03, 2025 11:27 am
Thanks Ian - so it should flash with a coded sequence? If I am honest, when it's flashing it's pretty consistent.
Post by Ian » Thu Jul 03, 2025 3:37 pm
Others will know better than me, but to interpret the coded hold light sequences on a post-99 Bongo you need to attach an OBD-11 scanner to the ECU. But I would guess that you will end up with a fault code of PO700 which means the gear box solenoids are failing.
But check the leisure battery issues first.
BaileyBongo
Post by BaileyBongo » Thu Jul 03, 2025 4:30 pm
Thanks Ian
I am more thinking it's either the split charger or LB that the issue is with now as I fully charged the LB before transferring over to charge the main battery directly. It had been on charge for about 12 hours and reached 14.4 but never actually clicked over the 'full' on the charger so implying that it's 'sapping' from the main battery
Post by g8dhe » Thu Jul 03, 2025 6:02 pm
If your trying to charge a battery which has a Split Charge Relay attached then yes, it will operate once a battery reaches the trigger voltage normally between 13-14 volts, then you will be charging both batterie in parallel. You will need to disconnect the -ve terminal of the LB at least before charging either battery to avoid the relay operating and charging both batteries. Doing so will of course cause the ECU backup supply to fail and cause the error condition which will then flash at the next start.
BaileyBongo
Post by BaileyBongo » Thu Jul 03, 2025 6:24 pm
Ok so the plan is...
  • Measure across the LB when car is running
  • Disconnect the -ve from the LB and charge main battery (I think the split charge is working as the main battery is never reaching a 'full'
Think it's the LB(well maybe hope)
BaileyBongo
Post by BaileyBongo » Tue Jul 08, 2025 8:14 pm
Just wanted to come back on this and show not ignoring!
So, we've hit upon a bigger problem - overheating yet again #-o (in April I only had the head gasket changed).
Drove it about 2 miles on the weekend and temp rocketed up & tank bubbling, put new coolant in see-saw method for getting the air out and it was all ok idling (temp staying where it should) - thought I had sorted it. Nope, just drove it again for about 2 miles and temp up again, seems to be whining in lower gears now so not sure where that has come from. Think Bailey will be taking a trip back to the garage for the foreseeable. [-o< its not too much
