Could this be a coincidence
Eratosthenes
Post by Eratosthenes » Wed May 28, 2025 3:25 pm
Over the last few days my exhaust, rear or mid box V6 Bongo, has got increasingly noisy and the noisier it has become there is a distinct loss in power on hills and at lower revs. When the revs eventually pick up power seems to be restored. Could this be a coincidence indicating I have another problem, or can the exhaust issue affect the power?
I have googled this and some say it will affect power and others say it wont.
It is booked in for exhaust replacement tomorrow.
Any comments or tips appreciated.
Re: Could this be a coincidence
Post by g8dhe » Wed May 28, 2025 3:32 pm
Yes the exhaust system causes a back pressure and often there are sensors in the exhaust systems as well, these combine to affect the engine, so a leaking exhaust will probably cause less back pressure and a change in flow rate over the sensor and hence affects engine performance.
Eratosthenes
Post by Eratosthenes » Wed May 28, 2025 3:48 pm
Geoff,
Thank you for the reply and explanation. Hopefully one less thing to worry about.
