Anyone got the mazda part number, I think I may need one.
Tom
Fuel cut solenoid
Fuiel Cutout Solenoid.
The number of a Mazda?
Choose from:-
323 1990 - 2000
626/MX6 1993 - 1997 2.0
626/MX6 V6 1993 - 1997 2.5
929/S V6 3.0 DOHC 1990 - 1995 JE-ZE
B1600 1972 - 2006
B2300 2WD Pickup 1994 - 1997 2.3
B2300 4WD Pickup 1994 - 1997 2.3
B3000 2WD V6 Pickup 1994 - 2007 3.0
B3000 4WD V6 Pickup 1994 - 2006 3.0
B4000 2WD V6 Pickup 1994 - 2007 4.0
B4000 4WD V6 Pickup 1994 - 2007 4.0
MPV 2WD 1989 - 1995 2.6SOHC
MPV 2WD V6 1989 - 1998 3.0SOHC
MPV 4WD V6 1989 - 1998 3.0SOHC
MX-3 4-cyl 16V DOHC 1994 - 1996 1.6DOHC
MX-3 V6 24V 1992 - 1996 1.8DOHC
MX6 1988 - 2002
Miata 1994 - 2005 1.8DOHC
Millenia 2.3 V6 1995 - 2002 2.3DOHC
Millenia 2.5 V6 1995 - 2002 2.5DOHC
Navajo 1991 - 2000
Protege DX, LX 1995 - 1998 1.5DOHC 4 DOOR
Protege ES 1995 - 2000 1.8DOHC 4 DOOR
RX-7 Turbo 1993 - 1995 13B
RX2 1993 - 1996
RX3 1993 - 1996
RX4 1993 - 1996
RX8 1993 - 1996
Choose from:-
323 1990 - 2000
B1600 1972 - 2006
MX6 1988 - 2002
Navajo 1991 - 2000
RX2 1993 - 1996
RX3 1993 - 1996
RX4 1993 - 1996
RX8 1993 - 1996
It is the fuel cut solenoid located near the fuel pump. The description is as per the manual. I have had an intermittant problem of it failing to open when starting. It may be the wiring which I will check this afternoon but I would feel happier replacing the solenoid itself - just in case.
Tom
Thanks for your interest btw
Tom
Fuel Cut out
I am sorry but I cannot help on this one. I have been trying to identify the actual fuel injection pump but no-one on the forum came in with an answer.
