Cooling fan
newtonlord12
Cooling fan
Post by newtonlord12 » Sun Mar 16, 2025 11:11 am
Hello again everyone, having some trouble with the fan now.
The fan comes on and stays on the second i turn the key two clicks. Have taken a look in the other chats and found that the cable that goes into the engine ( drivers side ) is perished and the cables are all corroded.
Does anyone know where i can find a cable to replace it with ? Have taken a look online for on and they are all just one end and open wires on the other end and not the plugs on both sides that this one has.
Any help would be greatly appreciated thank you, Newton
M reg 2.5L Diesel 2wd
Re: Cooling fan
Post by g8dhe » Sun Mar 16, 2025 2:57 pm
First which fan? If the radiator fan are you sure you haven't turned the aircon on? If its on then the radiator fans run as both the aircon and the coolant radiators share the fan!
As too the corroded cable, do you mean the wiring loom itself is shredded ? A photo would help as there are LOTS of wiring and cables!
