Transfer case replacement
Battle bongo
Post by Battle bongo » Tue Dec 24, 2024 5:48 pm
Hi all I’m a first time poster had my bongo for about 8 months and was wondering if anyone has put a transfer box in from another vehicle that has the capability to switch range ( 2high, 4hIgh & 4low) as I would prefer 2 wheel drive most of the time with the availability to go into 4wd
Any input is appreciated
Re: Transfer case replacement
Post by Bob » Tue Dec 24, 2024 7:43 pm
Welcome aboard.
The drive is normally to the rear wheels only, there is a viscous coupling behind the gearbox which transfers some drive to the front wheels when it senses a rear wheel start to spin.
Hope that helps.
Battle bongo
Post by Battle bongo » Tue Dec 24, 2024 9:30 pm
Bob wrote: Tue Dec 24, 2024 7:43 pm Welcome aboard.
Hope that helps.
I read somewhere on here that it’s a chain driven gear for the transfer case and mine feels and acts like it’s 4wd all the time
Post by g8dhe » Tue Dec 24, 2024 10:17 pm
Yes the transfer box itself is chain driven but the drive to the front wheels is via a Viscous Clutch which only engages the power when there is a speed difference between front and rear wheels see the diagrams, hence you are 2-wheel drive all the time and 4-wheel drive only when there is slipping;
Main page https://www.lushprojects.com/bongopartsmk2/
Transfer case; https://www.lushprojects.com/bongoparts ... mgno=.html
Transfer gears & Viscous Clutch; https://www.lushprojects.com/bongoparts ... mgno=.html
Battle bongo
Post by Battle bongo » Tue Dec 24, 2024 10:50 pm
g8dhe wrote: Tue Dec 24, 2024 10:17 pm Yes the transfer box itself is chain driven but the drive to the front wheels is via a Viscous Clutch which only engages the power when there is a speed difference between front and rear wheels see the diagrams, hence you are 2-wheel drive all the time and 4-wheel drive only when there is slipping;
Ah ok thanks I get it now but do you know of any other transfer box’s that might fit as I would still like the option for 4 low sometimes and being able to have it locked in to full 4wd without relying on a viscus clutch I’m wanting to make it as capable in mid as I can due to my plans with it
Post by Bob » Wed Dec 25, 2024 12:58 am
Sadly, no.
Post by g8dhe » Wed Dec 25, 2024 10:51 am
Never heard of anyone playing about in that area, not sure how you could have the front wheels at a different ration from the rear in a Bongo setup, it seems to be very capable in its original design too be honest!
