Rear Shock absorber bolts
beachguild
Post by beachguild » Fri Nov 01, 2024 4:31 pm
Does anyone know what size the rear shock absorber bolts are, the ones on my bongo are seized and need to be cut off, so I could probably do with 4 sets and I don't have access to the bongo at the moment so can't measure them.
Dave Lewis
Transit Driving Bongoer
beachguild
Re: Rear Shock absorber bolts
Post by beachguild » Fri Nov 01, 2024 4:33 pm
As an aside, someone mentioned that ford ranger bolts fit fine
Dave Lewis
Post by g8dhe » Fri Nov 01, 2024 5:32 pm
If you mean part number 9YA161401 you can try Googling for its availability but they don't normally specify the dimensions :-(
https://www.lushprojects.com/bongoparts ... 02.html#13 Mechanical diagrams,
part number search https://www.google.co.uk/search?q=9ya16-1401
beachguild
Post by beachguild » Fri Nov 01, 2024 6:34 pm
Thanks Geoff, interestingly the Ford Ranger bolt comes up in that search although it has one character difference in the part number
Dave Lewis
beachguild
Post by beachguild » Mon Nov 11, 2024 3:16 pm
I managed to source some bolts from Bongo Spares, Bongo Parts also had them. Both were from an old bongo, but have done the job fine. So hang on to those old bolts folks, new ones are rare unless anyone knows of an alternative part.
Dave Lewis
Post by g8dhe » Mon Nov 11, 2024 3:52 pm
Good to hear that you sourced some.
Might be worth measuring these things up when people replace parts these days as they are only going to become rarer as time goes on and even recovered parts might not be adequate!
sandoval
Post by sandoval » Mon Nov 18, 2024 7:38 am
Rear Shock Absorber Bolt Size:
Bolt Size: M12 x 1.25 (fine thread)
Length: Typically 75mm to 85mm
Post by g8dhe » Mon Nov 18, 2024 9:41 am
Ah excellent info.
