Tyres and pressure
Jule1
Tyres and pressure
Post by Jule1 » Sat Oct 26, 2024 7:51 pm
Hi have been reading some of the threads on tyres and am very confused
I have a 95 4wd diesel and the current tyres on it when brought are 215/15 R15C all the way around and was informed front is 30 psi and back is 34 psi
I have read the front tyres are meant to be 195 and am totally confused about this and not sure if I need to get these tyres changed also states this on the door sticker. Do not want to damage drive train if this could happen but don't want to change them if not needed as money is tight
Also feels a bit too loose on the steering and am wondering it is just because I am new to the bongo or the tyres/tyre pressures are wrong
Please can someone tell me what is the best thing to do thanks so much
Re: Tyres and pressure
Post by g8dhe » Sun Oct 27, 2024 9:30 am
Yes the stated values on the drivers door always seem very low for use in the UK. Most people tend to run 38PSI on the front and 40PSI on the rear tyres.
Post by Ian » Sun Oct 27, 2024 10:41 am
And 215s all round will be just fine.
Jule1
Post by Jule1 » Mon Oct 28, 2024 7:04 am
Hi thankyou so much so front tyre 38 psi and rear 40 will be OK all the time it's not fully converted just part so only one seat in the back not overloaded
